Question After a build, nothing is booting up. Are all these parts compatible?
brucedamstedt
14
Ryzen 3200g
Gtx 1060
Gigabyte A320M-S2H
16Gb corsair vengeance
EVGA 600w
and
NZXT H510
We tested all the Power supply components and they seemed to all be working, the case pins are plugged in to the correct spots, but nothing is turning on when we plug in the power cords. We believe that the CPU somehow got damaged, but we are not sure if that’s the case.
Thanks
hotaru.hino
Notable
Sep 1, 2020
1,122
348
1,140
27
I'm suspecting the motherboard, depending on which revision you got. The first revision of the board is not compatible with the CPU without a BIOS update. I can't find a release date for the second revision, unfortunately, so I can't tell if it should be compatible or not out of the box.
