Description of Original Problem: I've had my computer for about a year and have always gamed on an AOC CQ27G1 27' @ 1440 144Hz without issue. Most games at ultra settings. Yesterday, I added a second monitor (1080 60Hz) to my computer and ever since then, I've started getting VERY bad screen flickering in random games. The screen flickering doesn't appear to be a VSync type of flickering. It looks as if someone started violently wiggling my DisplayPort cable. My audio runs from the monitor as well, and the audio cuts in synchronization with the display flickering. video example
Computer Type: Custom
GPU: XFX Radeon RX 580 8GB DDR5 | Model No. RX-580P8D. Not overclocked.
CPU: Intel i3-4130 @ 3.40GHz. Not overclocked.
Motherboard: ASRock Rack H87WSA-DL
RAM: CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600
PSU: Corsair RM 550x; 550 WATT
Operating System & Version: Windows 10 Home 1909 18363.592
GPU Drivers: 19.50.19.19-200228a-352369C-RadeonSoftwareAdrenalin2020
Chipset Drivers: 10.0.18362.387
Background Applications: Steam, Chrome, GOG, Rockstar Games Launcher
Troubleshooting:
Swapped cables from DisplayPort to HDMI and back. Unplugged secondary monitor. No discernible difference.
Ran ATS in OpenGL, Safe Mode, and Direct X. OpenGL provided best results. Still screen flickering, but less frequent. Not playable.
Ran games in windowed/full screen. Ran games with full screen optimizations disabled. Disabled/enabled VSync. No discernible difference.
Downloaded Windows Media Creation tool. Formatted HDD and SSD. Reinstalled windows fresh.
Uninstalled GPU Drivers. Reinstalled.
Installed monitor drivers after factory resetting monitor.
Power cycled machine.
Set main monitor to all refresh rates between 60 Hz and 144 Hz
Notes:
Screen doesn't flicker when doing anything outside of video games
There was no flicker prior to the addition of a second monitor. Each of the games listed could run at or near max settings without issue.
Audio, which is connected to the impacted monitor, cuts out in synchronization with screen flickering.
I've had this computer and most of these games for a while now. This issue has never occured prior to the addition of the second monitor. Removing the second monitor does not seem to fix the issue, though.
When launching games through Radeon Adrenalin, Radeon Adrenalin does not recognize any performance issues.
Nothing seems wrong in Task Manager when the games are open.
No integrated graphics
Troubleshooting:
Notes:
