After effects and Photoshop problem
TheNewBie332
33
When i import a picture that i make in photoshop it says: photo is missing frame 3" and doesn't show the photo. It worked before.
[/url] [/img] Also, when i import an mp3, it goes to my last saved project on screen
[/url][/img] what would cause this? thanks.
Could you double check your hmtl for your images in the post? #2 works fine. #1 is too small (no link). #3 and #4 are not there.
there is no 3 & 4, i have no idea why it said there was.
Weird coding then.
Do you have a larger image of the first one? The thumbnail doesn't link to a larger image, so the error is impossible to read.
And what kind of file type are you importing? You said it was done in photoshop, so is it a .psd file? Or saved as a .jpg or the like? I'm wondering if it's trying to import layers as frames.
i no longer have pic #2. but zoom in, and it says missing frame 3 cannot import. Also i was trying to import a png
