Greetings everyone,
yesterday during the night my PC experienced a power outage. I was sleeping then, my PC was on full load when it happened (it was mining with the GPUs).
Following things happened/ I observed:
- I bought two new GTX 1070 Ti for myself, for gaming and for mining. One GTX 1070 Ti survived, but it is only working in the lower PCI Slot. If I plug it into the upper slot, I only get a blackscreen and I cannot even access the BIOS. I am not going to use my GPU until I got a new PSU, and MB because I do not want to destroy another GPU. I have warrant on both of them (bought them 3 months ago), but it would be a bad move, nevertheless.
- My other GTX 1070 Ti which was plugged in the first PCI Slot did not survive. KIA, Killed-In-Action. The GPU does not work inside the other slots as well, and I get the same symptoms my old GPU gave me which is that it makes my PC freeze and crash if it is plugged into the lower slot. In the upper slot it does not boot at all, black screen. It does not even get recognized properly. It looks like this is GPU-Z; https://i.gyazo.com/a3af056844125b58...644ca6e420.png
-Like I already said, my first PCI Slot does not work at all, even with the working GPU.
- I think the PSU caused it. I think the PSU destroyed the first GPU and the Slot it was plugged into. I am not sure though, maybe the GPU or the Motherboard is the cause which I highly doubt though. I will buy a new PSU for myself to 100%. My PC works currently, but I am on it with my IGPU.
What do you think, what caused the problem? How could my GPU get destroyed and the Slot it was plugged into as well? I will send my GPU back, since I have warranty with it. I have to buy a new CPU, Motherboard, PSU and RAM though, which will cost a lot. Damn it.
