After power supply change hard disk light is always on
Can you elaborate a little? Does the PC boot into windows?
yes, xp with 3 hard discs. and all is perfect.
Does the light shut off when you power off?
yes, and there are not additional evidence of "extra" hard disk activity, all function normal, idle time all well, is very strange... or may be there is hide hard disk activity...?
thank you for your support...
all function normal, NOTHING ABNORMAL AT TASK MANAGER...THERE ARE NOT ADDITIONAL CONSUMING CPU RESOURCES. MAY BE THE MOBO. PATH TO HD LIGHT IS DAMAGED OR THE HD LIGHT OR SOMETHING WAS DAMAGED BY THE LATER POWER SUPPLY...
