check what the setting for the controller is.
if it is set to AHCI, change it to IDE, or the other way around.
Thanks so much for your quick response. I don't see, in the BIOS settings, where I set the controller. I have Standard CMOS Features, Advanced BIOS Features, Integrated Peripherals, Power Management Setup, Pnp/PCI configurations, PC Health Status, and MB Intelligent Tweaker (M.I.T.). Do you know which category I should find controllers under? Apologies for my ignorance but I sure appreciate your help.
I see IDE Prefetch Mode [Enabled] under Integrated Peripherals.
The problem seems to be that I can't get the system to recognize my OS on Drive C, and my slave on Drive E. I don't know how to get it to recognie that they are there. They don't show as BIOS options.
