After restore to prior setting, XP will start, but goes to..
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.perform_maintain (More info?)
After restoring to prior date, lost power during restart, and it goes to safe
mode, from which it will not change. I have a blank screen after any
configuration changes.
My software was installed by another individual, who is in Iran. Is there
any way that I can restore the computer, without the software?
Craig
532
You have a couple options to try...
1) Go into SAFE MODE by pressing F8 when you power up the system.
- from the RUN dialog box type the following to start the SYSTEM RESTORE :
c:\windows\system\restore\rstrui.exe
as per KB279736 ( http://support.microsoft.com/kb/279736)
2) You can follow the steps from KB307545 . You don't need to have the
Windows XP cd, you can use a Windows 2000 or 2003 cd to get to the recovery
console. If you don't have access to any of those, you can try to create a
bootable cd from --> http://www.nu2.nu/pebuilder/
[How to recover from a corrupted registry that prevents Windows XP from
starting]
http://support.microsoft.com/kb/307545
I hope this helps.
Craig
Microsoft Setup Team
Search our Knowledge Base at http://support.microsoft.com/default.aspx
Visit the Windows 2000 Homepage at
http://www.microsoft.com/windows2000/default.asp
See the Windows NT Homepage at
http://www.microsoft.com/ntserver/
NOTE: Please reply to the newsgroup and not directly to me. This allows
others to add to and benefit from these threads and also helps to ensure a
more timely response. Thank you!
This posting is provided "AS IS" without warranty either expressed or
implied, including, but not limited to, the implied warranties of
merchantability or fitness for a particular purpose.
The views and opinions expressed in this newsgroup posting are mine and do
not necessarily express or reflect the views and / or opinions of
Microsoft.
