After using PC for a bit, no display
baniDJ
385
Hello guys.
Haven't turned on my PC for a week and yesterday I start it and everything works fine as it should, but after some time, after playing GTA V, CSGO or just even while idle while playing music in background the display would go off, after I restart the PC it works almost everytime good, but sometimes, really rear, it doesn't display anything in the monitor, and I have a debug monitor on mobo it gives me a code d6 or smth like that I don't remember now, but I guess it is a problem with my graphics card. Also what I have noticed is that sometimes when the PC is turned on, while the BIOS, and other stages of setup are going the fans are running at normal speed, but when it starts windows the Fans speed at max untill afterburner starts. I don't know what is the exact issue and how shuld I solve it. I tried pulling the GPU out and puting it in again and checked all the cables, reset the BIOS, but nothing worked. What should I do, please help!
The specs are:
FX 8300 3.7 Ghz (temps never go over 63C)
Asrock 970 Extreme4
12 GB 1333 Mhz RAM
128 GB HyperX SSD
500 GB WD Blue HDD
MSI Gaming R9 270 (stock, never goes over 70C)
