Question After using streched res my hz went from 144 to 120 and i cant change it
Dec 8, 2021
So recently i simply i began to use streched res in games, shortly after i realised that my hz capped to 120 and i cant do anything about it, i tried everything to fix it but there is simply no solution for this problem (AMD user) PLS help
Dec 8, 2021
7
have you tried custom resolution utilty? if not maybe use normal resolutions. I was having this issue when I was using a hdmi gpu instead of a displayport one.
