AFTERGLOW Sound of justice problems
kevin385874
11
I believe this headset is the same as the PDP AG 9 but im using the usb reciever on my laptops and everything works fine but i use it on my main pc and whenever there is any sound made by the mic it completely goes crazy and makes loud noises and after you stop talking it goes away(Only happens when sound is going through mic)
I have checked for interference(Unplugged modem,phones and other stuff)
I encountered this as I use the Afterglow headphone, my issue was due that I use a USB video cam for skype and the microphone from that cam was double feedback and causing a mess of a noise., I disabled the mic on the cam, and made sure the mic on headphone was default.
