Hello Guys,
I currently have a Zotac GTX 670 reference card (But with a 680 PCB). Here's a link to the card.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814500266
I know its better than the reference small 670 PCB cards out there but my temps hover around 82-84 degrees when playing Witcher 2 or Battlefield 3. I even tried setting up a fan profile on EVGA precision but the cooler is loud and still my temps go upto 71-72 degrees at max fan settings.
I was thinking if I should get myself an aftermarket cooler like the Gelid Icy vision or the Accelero Twin Turbo II. The Gelid costs around 60 to 65$ and the Arctic Accelero costs about 44-48$. But I am worried if it would justify the cost spent on the cooler. I mean, I have a negative pressure airflow inside my Phantom Full tower case as there is only 1 140mm intake at the front and the rest are all exhaust fans. What do you suggest guys, Should I stick on to the reference cooler itself of should i get an aftermarket cooler. If I get the cooler, then I would like to overclock it as well but I am worried about the airflow inside my case.
If you need my system specs, then check my profile signature.
