Aftermarket cooler for PNY GTX 760
leon909
40
Does anyone a good but cheap aftermarket cooler that will definitely fit my PNY GTX 760 as the temperature on the stock heatsink and fan get to around 50-60°C while playing games like BF4 on high settings and Warthunder on max.
that's totally fine.... the max temp on those is like 80 or 90 something. You're way below that.
besides, there's no such thing as 'cheap' aftermarket coolers... you'd probably be looking at 70 or 80$, which is alot for a $250 GPU that doesnt even need cooling help
Agreed. 50-60 degrees is a perfectly acceptable temperature for a modern GPU. You probably won't find anything made for the 760 in the first place, but even if you did, most aftermarket GPU coolers are going to cost quite a bit of money because of their target market of being used on $400+ video cards.
