Aftermarket Cooling fitment Issues?
Leonstryfe
17
Hey guys, I really like this mobo but I'm not sure which aftermarket cooling device will fit?
This is the mobo
EVGA 122-CK-NF68-AR Socket T (LGA 775) NVIDIA nForce 680i SLI ATX Intel Motherboard
Also I'm getting a 8800 GTS
with a E6600
which will be OCed thus the need for aftermarket cooler.
I read in reviews that certain coolers wont fit.. What should I get? Definitely need a CPU cooler, and what other cooler would I need as well?
The problem with this board is that it has ?capacitor? on the back of the mobo under the socket area. Any cooler with a backplate will need a little tinkering. Something as easy as adding some padding between the backplate and the mobo should prevent the back palte from crushing them
