N nukchebi0 Distinguished Jul 8, 2006 690 0 18,980 Feb 4, 2008 #1 Does anyone know an aftermarket cooler that doesn't exceed $25 and is guaranteed to fit the motherboard without any problem? Please respond quickly.
Evilonigiri Splendid Jun 8, 2007 4,381 0 22,780 Feb 4, 2008 #2 http://www.newegg.com/Product/Product.aspx?Item=N82E16835103031 This is an excellent cooler for the money. The downside is it's a bit noisy.
N nukchebi0 Distinguished Jul 8, 2006 690 0 18,980 Feb 4, 2008 #3 How big is it compared to a stock cooler?
Evilonigiri Splendid Jun 8, 2007 4,381 0 22,780 Feb 4, 2008 #4 Quite big really. There should be dimensions listed in newegg.
N nukchebi0 Distinguished Jul 8, 2006 690 0 18,980 Feb 4, 2008 #5 I'll think I'll just stick with the stock cooler, then. I don't want any issues with something not fitting. My Northbridge heatsink is located not far below the CPU socket, and is really tall.
Evilonigiri Splendid Jun 8, 2007 4,381 0 22,780 Feb 4, 2008 #6 Heatsinks are designed so they can fit, but if you're not going to OC, keep your stock cooler.
N nukchebi0 Distinguished Jul 8, 2006 690 0 18,980 Feb 4, 2008 #7 I was going to go to 2.2 Ghz with the X2 3600+, so the stock with MX-2 should be sufficient. The X2 3600+ is 2.0 Ghz at stock.
