Ai Charger+ for Asus Ai Suite 3
Jergens Healing
8
Hi folks, I have a TUF SABERTOOTH 990FX R3.0 motherboard. See link for full specifications https://www.asus.com/us/Motherboards/TUF-SABERTOOTH-990FX-R3-0/specifications/
Questions:-
1. Does Ai Suite 3 come with Ai Charger+ for this motherboard?
2. If it does, then how do I install and use it?
Thanks in advance.
As above:
1. According the Asus support page I linked to, what will be installed with AI Suite is specific to the MoBO in question.
2. The version that should be installed, I expect, is the one referenced in your manual.
3. Neither your manual, nor anything in my post, makes reference to Ai Charger
4. Please read your manual for explanations of the various features. USB Boost is not fast charging but teh name and your manual does describe what it does do:
USB 3.1 Boost technology supports UASP (USB Attached SCSI Protocol) that automatically
speeds up the transfer rates of your USB storage devices
Transfer rate is the speed at which data moves thru the interface, charging rate describes hpow fast the...
https://www.asus.com/my/support/FAQ/1012780
AI Suite 3 is an all-in-one interface that integrates several ASUS utilities and allows you to launch and operate these utilities simultaneously.
You can download this untility in ASUS support site: http://www.asus.com/support/ according to your specific model.
*Enter product's model name-> Support-> Driver & Tools-> Select OS-> Utilities-> ASUS AI Suites 3
http://dlcdnet.asus.com/pub/ASUS/mb/SocketAM3+/SABERTOOTH_990FX_R3.0/E11421_SABERTOOTH_990FX_R30_UM_WEB.pdf
See section 4.4 of your manual (Page 4-3)
4-3
4.4
AI Suite 3
Thermal Radar 2
USB 3.1 Boost
EZ Update
System Information
USB BIOS Flashback
Push Notice
Version
Thanks JackNaylorPE, but this is not what my Ai Suite looks like. If you go to the drivers download page, the version of AI Suite for TUF SABERTOOTH 990FX R3.0 motherboard does not include Ai Charger. I am assuming that "all" usb 3.0 ports allow for fast charging. So my questions remain the same
Sorry for the confusion.
As above:
Transfer rate is the speed at which data moves thru the interface, charging rate describes hpow fast the batteries charge for connected devices.
