I have cube gaming axel case / tecware fusion / sama im01 which is similar to coolermaster nr200. Since i will be mounting my gpu vertically, I'm planning to buy aio liquid cooler. The one i had in mind is arctic liquid freezer II. Not really planning on overclocking my ryzen 5 3600x. The only option to mount radiator is at the top position of the case. My question is, which one will be a better solution overall in term on cpu cooling and airflow
Scenario 1, using 240mm aio
Scenario 2, using 120mm aio with 1 case fan beside it.
Excuse my bad english. Thank you
