[SOLVED] AIO 280 or 360 for 10900K
Multyspeed
164
24
18,615
Hi all.
I'm about to buy 10900K and i want an AIO. The problem is that i can't decide between 280 ot 360 rad.
Is the performance difference big ? And does the 280 AIO enough for the 10900k ?
often the performance is none to a a few Cs lower, go for the 360 if you can mount it on top of the case, else go 280 on top of the case as well.
280mm is fine for stock operation.
If you intend to try and push this cpu with its already limited OC headroom, pass on 280mm and 360mm low noise models.
Be aware that the airflow through this chassis is strained by design. Do not expect extraordinary thermals, even with the 360mm hybrid cooler.
Yes I see that. But she is not going to overclock the CPU for now (by she I mean, I'm not going to clock it)
But for normal use the case will be ok.
Thanks a lot to all of you. I'm going for the 360 AIO front mounted.
