Good afternoon, I have what I hope is a simple question someone can answer for me. I am building a new systtem with a few leftover parts from my old system. New system will be on an Asus Strix B550-E motherboard and I am hoping to add some new RGB fans with Asiahorse FS 9002 fans. The question is I have an older Corsair H100I GTX AIO cooler that has two plugs coming off the pump. A pump power cable that is supposed to be plugged into the CPU_FAN header and a doubler that is supposed to be plugged into the two fans.
If I use the new Asia horse fans, that have a proprietary plug that goes into the included control box (PWM able) and then plug the PWM Fan from the control box to the CPU_OPT , do you think that would be ok? Or do AIO Fans run much higher then other fans and therefore would all my fans always be ramped up??
My motherboard also has an AIO_PUMP header. Can I just plug the 3 pin cord into that and then the PWM control box into CPU_FAN??
IF someone has a better way of going about doing this I would love to hear it as well. Thanks!
