Brand new PC build, but the watercooler AIO and radiator fans turn on with PC startup, then off after about 2 seconds, then on again and repeats at a consistent pace. PC Boots and functions fine otherwise.
The RGB on the fans also turns on and off at the same time the radiator fans do.
Case fans spin constantly and do not stop, only the radiator fans and AIO cooler. what could be causing this? Does this seem like a cooler problem? power supply problem? maybe motherboard problem?
Specs:
Ryzen 5 3600x
Auraflow 240mm AIO
Msi b450m bazooka
Team T force DDR4 3200mhz RAM
Rosewill HIVE 650 W Bronze PSU
Specs:
Ryzen 5 3600x
Auraflow 240mm AIO
Msi b450m bazooka
