[SOLVED] AIO Cooler and Fan headers.
Jan 2, 2019
I just received my thermaltake floe 280 aio cooler and had some questions on wiring the components. I have an Asus z370e MB and current have the pump plugged into in the aio pump header. My question is should I plug the two fans on the radiator into the CPU_FAN & CPU_OPT header or plug into the provided thermaltake controller. If I plug into the controller will it automatically control fan speed as the CPU heats up or will the fan speed only amp up with it plugged into the CPU _FAN & CPU_OPT headers.
Ideally I'd like to control all of the rgb lighting through one program instead of using aura and the thermaltake software.
Any advice would be greatly appreciated.
