Hi,
I have a Cooler Master ML240L RGB connected to an ASUS ROG Strix B450-F Gaming II.
The Pump is connected to AIO_PUMP socket, both radiator fans (using a splitter) are connected to CPU_FAN plug socket.
When I turn on the PC, the liquid cooler fans start up at full speed and then spin normally.The PC does not give any type of error, everything works correctly in Windows and in games, the temperatures are also normal. Everything works perfect, except for that little detail when the PC starts up.
This is normal? Or is there a way to solve this?
I hope you can help me.
Thanks!
Thanks!
