Question AIO cooler options without USB 2.0 header
You can run most of them without they’ll just be set to a default fan and pump curve. You also might want to get one that doesn’t have a display as that can’t be changed or turned off either.
What’s the issue with the USB2 header?
The motherboard I have (Asrock Z690 PHANTOM GAMING-ITX/TB4) only has a single USB 2.0 header which is already being used.
That cooler is not listed on the motherboard’s compatibility list.
I've never even heard of such a thing. Yes, there are odd issues from time to time, but apart from RAM placement and clearance, if a board uses a given socket/hold down system and the cooler you're buying supports that, you're good to go.
Reactions: CountMike
