Hello all,
I am getting a Swiftech H220 AIO to cool my 4790k CPU and the NZXT H440 case to be the new home of my power house. I have some questions regarding what the best mounting options and fan orientation as this is my first liquid cooler and build...
1) Should I mount the radiator on the front or should it be mounted top of the case?
Seems like majority or people mount the radiator on the top of the case, however I have heard some stories that a front mount equals better cooling for the NZXT.
I was planning on using my fans in a pull configuration (pulling air out of the case or pulling air in) around the radiator (to prevent dust buildup) Although if I do a Front mount guess that would not matter due to the dust catch.
Relevant specs:
Case: NZXT H440
Cooler: Swiftech H220
x1--Corsair AF quiet edition 140mm
x2--Corsair AF Quiet Edition 120mm
x2—Noctua NF-F12 120mm (was going to mount on the radiator)
Another concern with a Front mount was my Graphics card, its big a r9 290x Sapphire tri-x. I have to remove some drive bays as is. Would this interfere with tubing of the H220? (Especially if mounted in front)
All thoughts, opinions and justifications will be very useful.
Thanks All!
Build: http://pcpartpicker.com/user/GiggsBoson/saved/6z2bt6
Relevant specs:
Case: NZXT H440
Thanks All!
