Question AIO cooling unit causing failure to POST
Aug 22, 2020
so, recently my father pulled out his older gen 1 AIO cooler from his old Alien ware PC, purchased a new mounting bracket set and everything, i installed it, and when i start my PC, it will start but no POST not even a Boot, i had a bent pin on the CPU bracket, fixed that, no dice, brackets an LGA1150, power supply is currently running at 750 watts, so the PC will start as mentioned before, no recognition of the USB connections, no recognition of the screen, nothing, then after a few seconds the PC will shut down and then will restart endlessly, only fixed when i fixed a bent pin i had and re installed the stock intel CPU cooler. i should note that i literally gutted the PC to just CPU, Cooler, and RAM and this was still happening.
