Hello folks im having a little issue here cooler master seidon 120v v3 plus liquid cooler . This cooler comes whit 2 fans can any one tell me the best fan position for the best cooling performance ? Exaust and intake positions
Always as exhaust, if possible, as it will lower your case/gpu temps as well.
See that you mount the rad to the case first, attaching the fans on the inside,
so when you need to clean it, it only requires you to remove the fans (from the rad) to clean the rad.
Intake would allow for fresh/cooler ambient air to draw into the radiator and cool the processor but it eventually dump into the chassis raising the temps in turn. You might want to install the cooler in exhaust and make sure you have a good airflow as well as intake to help keep the innards and the radiator cool.
