Question AIO fans aren't showing up in icue
Sep 2, 2019
11
So i turned on my first pc build yesterday and everything has gone smoothly. I'm using 6 LL120 fans and an aio cooler with 2 fans. So my 6 fans are all connected to the commander pro for power and the rgb hub (which is then connected to Commander Pro using the led slot. These work fine in Icue however i had my 2 aio fans plugged into the aio pump and although they lit up and spun i couldn't see them in Icue. I tried plugging the rgb cables into a secondary rgb hub then connecting that to the commander pro in its second led slot but they don't light up at all now. Where am i going wrong? or could this be a bug?
Any help would be appreciated.
