Hello,
I'm getting the Msi 1080 seahawk x and I don't know where to put the card's radiator and fan.
My case is the fractal design define r4 window and my current cooling setup is:
- 2 x 140mm on front as intake
- 1 x 140mm on the back as exhaust
- coolermaster 412s cpu cooler with a 120mm fan on the front facing the back (push)
I was thinking of putting the gpu cooler on the back of the case as exhaust and move the 140mm from there to up as exhaust. Would that be a good place since the cpu heat would go on the gpu radiator and then out the back?
Thanks,
G
Thanks,
G
