Hi everyone,
My CPU temps were going crazy and after some internet troubleshooting I arrived to the conclusion that the AIO cooler pump was malfunctioning.
Some of the symptoms were:
Notes:
I sent the AIO cooler for repair expecting to get a replacement as all the behavior pointed out to a malfunctioning pump. After 2 days they are sending it back to me claiming to have been "repaired". When I asked what kind of repair they did on it they said they "reconditioned the pump".
My question is quite simple - can broken AIO pumps be repaired/reconditioned just like that ? The problem I see here is that the pump was not replaced but reconditioned instead. My warranty expires in ~ 1 month so I'm worried they may have applied some kind of trick to get it working a bit longer before it finally breaks outside of the warranty period.
Thank you in advance!
- Occasional grinding/shredding noise coming from the pump
- Fan running at 100% in even the slightest CPU loads with temps reaching up to 90-100 C
- Coolant pipes/cables barely getting warm
Notes:
- Thermal paste was re-applied recently
- CPU had no overclock, an I9 running at stock frequencies
