AIO Liquid Cooler in Meshify C
tajdunn2992
i currently have a Fractal Design Meshify C, with a Gigabyte ga h270 hd3 (rev 1.0) motherboard. i have two front intake fans and 1 exhaust fan, my problem is im not sure if a 280mm AIO liquid cooler radiaotor will fit in the top mount of my case which is where i plan on installing it. ive checked the dimensions of the radioator and measured the room from motherboard to top of case and it seems okay but im just worried it still wont fit.
Oh wow i read om the site "Top Fans- 2x 140mm" and thought okay sick i can get a 280mm radiator but completely missed the part where it clesrly states "TOP RADIATOR 1x240mm" thank you so much for help, not sure if this is how you reply, first time using this site for help with pc
Much appreciated
