AIO Liquid Cooler pushes on GPU
Oct 12, 2018
My Kraken M22 is pushing against my MSI Gtx 1070 Graphix card I wanna know if this is a huge issue or that's OK. I've included a picture. Whats updated after the picture is that Kraken M22 is now Pushpull at the back. Now it's pushing just a little more but the difference between before and after isn't noticeable.
https://imgur.com/a/VrY3QXW
If it's pushing against it, and it functions that way....I wouldn't be too concerned as long as where it's pushing against it is isolated electrically (no metal touching metal unless it's ground plane metal touching metal).
....and also...I wouldn't want the parts to be stressing to much.
...and finally.....vibration. You don't want them vibrating where they are touching because this will cause wear.
...but if the parts are isolated....and not stressed and not vibrating....I think you will be OK.
