I have a Nepton 240m mounted in the top of a Cooler Master Mastercase 5 Pro. I have the fans on top blowing down through the rad and the and the hosees to the block are at the bottom. Is this the wrong way to set it up. I can't get the fans inside blowing out because of space. I'm not sure if I can mount it in the front, as I haven't tried. Can someone who knows about air flow tell me if this is ok or can I just spin the fans around to pull air through the rad. I can't see this working worth a damn but what do I know. (not much obviously)
