About a year ago, I built a PC.
CPU : I7 8700 non k
AIO : coolermaster masterliquid lite 120
Recently, I was playing Witcher 3 and noticed quite a bit of vibration sounds. I alt-tabbed and noticed my CPU temps were at 100c.
I quickly shut off the pc, and booted into bios.
It still showed 80c and going up.
I remounted the cooler several times, although I am still not sure if it is mounted properly . The backplate is wobbly (when the heatsink isn't mounted) and I cannot refix it without removing the mobo out the case, but when I mount the heatsink and tighten the screws, the backplate seems to be fixed and not wobbly. I have reapplied thermal paste every time I removed the heatsink.
But nada. Temps in bios still go up and up.
When I check fan speeds in bios, it shows cpu_fan ( heatsink connected to this header) to be 2500-3000rpm.
This confuses me.
Any advice is welcomed.
Thank you!
CPU : I7 8700 non k
This confuses me.
- is my heatsink not in proper contact and this is why my CPU isn't cooling even at idle and in bios?
- is my aio messed up, and this is why CPU isn't cooling?
- is my CPU messed up?
- is it my motherboard?
Thank you!
