Hello!
I am interested in your opinions and experiences.
I'm building a new PC at the end of the month, which will have a Ryzen 7800X3D CPU, since it will be mostly used for gaming.
The processor cooler has not been decided yet. So far I have used air cooling for all my configurations, most recently a Noctua NH-D15S cooler.
Now I planned to use AIO water cooling. What is very important to me is that the PC is as quiet as possible.
What do you think, can the water cooling pump be so quiet that it cannot be heard 30-40 cm from me on the table and I can achieve better results with it than with an air cooling?
If I replace the fans on the radiator with silent ones, can I put together a system that is quieter than air cooling?
Should I stick with air cooling or switch to AIO?
My preferred water coolers are the following:
