Question AIO temp problem
Sep 25, 2019
13
Hello everyone
I have a corsair H115i and i7 7820x
Lately the cpu and the water in the AIO are too high.
The AIO when idle is 55 c , which makes the cpu go 80 c ( no overclocking)
It's been like this for about 2 weeks
I tried thermal paste which didn't do much
Today happened something very strange, I flipped my pc from vertical to horizontal to see anything happens
and nothing happened but when I flipped my pc back to vertical the cpu temp reduced from 80c to 30 c in less than 5 seconds
I turned off my pc in order to try again, and so it was , the initial cpu temp was 80 c .And when I did the flipping thing
it reduced to 30 degrees in an instant , and it stays the same temp as long as I don't turn my pc off.
Is there anyone who can help me
husum95
11
How old is your H115i?
Cause it kinda sound like the pump might be busted.
With the H115i, if you have the included microusb cable plugged into a USB header on the motherboard, you should be able to see and control the pump
