Hi guys,
I'm building a new PC inside a Corsair Obsidian 750D and would like some advice on GPU radiator placement.
The CPU will be cooled by an EK-KIT P360 Custom Loop Liquid Cooling Kit (first custom loop attempt) and I intend to mount the PE 360 radiator in exhaust configuration at the top of the case and put the GPU radiator at the bottom of the case similar to as shown in the following picture but in exhaust configuration https://ibb.co/dMvP8a
However, I’ve read on EVGA forums that this isn’t good because because “the radiator needs to be above the graphics card so that any air in the loop sits in the top of the radiator rather than being sucked through the pump and the rest of the loop, causing higher temps and poor pump life.” Is this true?
If so, my next thought was to mount it as an exhaust at the top back of the case, but then I’m worried about a potential compatibility/ space conflict issues between the 2 radiators like the following would be if the GPU rad was any depper, https://ibb.co/iFB0EF , and even in a picture of a completed build using the exact GPU I intend to use the fan / rad placement is very tight as shown here https://uk.pcpartpicker.com/b/J4MZxr
So - Any advice on how to check compatibility? If not what are my options? Go for an air cooled GPU?
Thanks in advance!
Full build: https://uk.pcpartpicker.com/user/angrywomble/saved/XdM8K8
Thanks in advance!
