Good day,
I'm currently running Ryzen 7 5800x paired with MSI B550M Mortar Wifi motherboard and using Cryorig H7 Quad Lumi for cooling.
My idle temp is 45-55 degrees and when I run cinebench R20 my temp rise to 90 degrees.
I am planning on replacing my H7 Quad Lumi with an AIO. Probably, NZXT Kraken x53 240mm. This will be my first time to use an AIO for cooling
and I am not sure if it will fit on top of my case, Meshify C Mini because of the motherboard heatsink.
I'd like to get your opinion on this.
Thank you.
Thank you.
