Air cooler for Case
Innocent Demon
41
Hello !
Components:
- Segotep G1A Silver Battle Edition
- MSI X370 Gaming Pro
I want to change the front and the back coolers that the case came with it, and i dont know what coolers to get, so the PC can start working.
Also, the motherboard supports 4pin cooler (i would like a 4pin cooler, instead of the 3pin).
The Fan Controller has a molex cable.
And the back cooler has 3pin and molex.
The front Air Cooler i think it has just a molex cable that it connects to the fan controller molex cable, then the back cooler connects to fan controller molex cable and the 3pin connects to the motherboards 4pin.
If you have alot of money, I would recommend the Nebula:
https://www.amazon.com/Noctua-NF-F12-PWM-Cooling-Fan/dp/B00650P2ZC/ref=sr_1_1?ie=UTF8&qid=1502968387&sr=8-1&keywords=pc+fans+noctua
They are extremely quiet and highly efficient.
If you dont like the looks, here are some cool looking ones:
https://www.amazon.com/Corsair-AF120-Quiet-High-Airflow/dp/B00F6S0XJO/ref=sr_1_3?ie=UTF8&qid=1502968504&sr=8-3&keywords=pc+fans
They are 3 Pin however you can get any adapter:
https://www.amazon.com/s/ref=nb_sb_ss_c_1_15?url=search-alias%3Daps&field-keywords=4+pin+to+3+pin+fan+adapter&sprefix=4+pin+to+3+pin+%2Caps%2C223&crid=1XUSW92VML3LC&rh=i%3Aaps%2Ck%3A4+pin+to+3+pin+fan+adapter
How about these, they are slightly cheaper:
https://www.amazon.com/Cooler-Master-SickleFlow-120-Radiators/dp/B0026ZPFCK/ref=sr_1_6?s=electronics&ie=UTF8&qid=1502968914&sr=1-6&keywords=pc+fans
These are 3 pin, you will need an adapter.
Unfortunately, if you get cheap fans you may find only little improvment in temps and air circulation.
These are quiet and large fans:
https://www.amazon.com/Rosewill-Sleeve-Computer-Cooling-ROCF-13001/dp/B00KB8CB9O/ref=sr_1_3?s=electronics&ie=UTF8&qid=1502968914&sr=1-3&keywords=pc+fans
