The 5950X is easier to cool than the 5900X. It was the same deal with the 3950X and 3900X.Ive heard many say 5800X is harder to cool than the big brother 5900x and even the 5950X?
No problem. It needs a decent cooler and does get hotter than say a 3800x but it’s still nowhere near as hot as some other CPU’s. Also there are air coolers that will equal or outperform a 240mm AIO.I heard the 5800x gets really hot under load is it sensible to air cool this cpu?
Ive heard many say 5800X is harder to cool than the big brother 5900x and even the 5950X?Intel's cpus have the high power draw without the thermal density(14nm).
AMD's Ryzen 3000 and up has the power efficiency without the surface area to properly dissipate the greater thermal density of the 7nm + MCM dies.
Just like the 3800X and 3800XT, the 5800X is the hot one in it's respective stack, but not because of power.
But yes, you can air cool a 5800X.
According to Tom's Hardware, the 5800X consumes about 10W less than the 5950X. So it wouldn't be harder to cool down based on that value alone. The only thing I can think of that would make it harder to cool is that heat energy is more concentrated due to there being only two chips on the 5800X while the 5950X has three.Ive heard many say 5800X is harder to cool than the big brother 5900x and even the 5950X?
The x95x Vs the x9xx makes sense to me: they're using their absolute best dies on the former.
I don't know what all AMD did with the x8xx chips, but it's terrible. I believe there's some extra heat from those dies that does not end up going through the heatspreader > paste > cooler cold plate cycle.
I would recommend the 3700X over the 3800X/XT because there was a 1 - 2% difference between them, and it ran a fair bit cooler.
3800X/XT were not worth it, even when it was on sale, IMO.
IF they ever release a 5700X, that would be great, but the naming has too much in common with the 5700XT - might even be why they skipped it, XD
The 5800X is in an odd spot.
The 5600X is by no means a bad cpu, but so many people who would be well served with it seem to justify the 5800X for that futureproofing nonsense - IMO(again) it's marketing BS and a fool's errand; you can never win that game.
The 5900X, on the other hand, is definitely a bit much for just playing games with... for people who actually need that many cores/threads, the Intel options just can't compete with it. AHEM! Availability aside, that is.
I was thinking I should be able to cool the 5900X better than I am currently.According to Tom's Hardware, the 5800X consumes about 10W less than the 5950X. So it wouldn't be harder to cool down based on that value alone. The only thing I can think of that would make it harder to cool is that heat energy is more concentrated due to there being only two chips on the 5800X while the 5950X has three.
How aggressive is the cooling system running? Are the radiator's fans pulling air in from the outside or from the inside?I was thinking I should be able to cool the 5900X better than I am currently.
Using a n NZXT Z63 im still hitting 72c in a 20c room under s CPUZ stress test. I was expecting mid 60s honestly.
High 60s and even 70 while gaming.
I have it in a curve 100% by 60°cHow aggressive is the cooling system running? Are the radiator's fans pulling air in from the outside or from the inside?
I use the vented side to run cooler. NR200@Bassman999
postimages.org or imgur.com
Make sure you take off the side glass panel to avoid reflections.
The idle temp fluctuates between 29C and 35cSounds like my 10900k in my 20C room.
Idle to me is chrome open with a dozen tabs but no videos games or rendering going on.
Presently 21* room 32* CPU
you too 😁20C/30C
Like I said... sounds like my system... and I agree about what idle is only I have at least 30 firefox tabs open.
Anyway... have fun.
Case Corsair NR200 (vented side not the TG@Bassman999
I'm still curious how the fan/cooler setup is, if you don't mind?
No, it's ok, I have an idea of how it's setup now.Ill take some pics and upload them, but my wiring is a ness so be forewarned lol. I just built it and didnt go and tidy up yet.
Hmm, I wonder if there isn't any gpu exhaust making it's way through the radiator...Case Corsair NR200 (vented side not the TG
NZXT Z63 280mm aio mounted on the side panel.
I have it setup pulling air intaking from outside.
and 2 top mounted TT Riing Trio 120mm fans exhausting the top of case.
