Air Cooling for 7700k with problems size
ZeusFede
114
Hi all , i have a Matx board , the Gigabyte B150M DS3H , a GTX 1080 , 3 ram slots ( 1xGB and 2x4GB of Kingston DDR4 2133) , a Seasonic 520 and a Corsair 400c .
I want to buy a 7700k obviously to no ocing right now because my motherboard dont let me , so i am thinking on an 280MM aio at front ( because in TOP dont fit ) , or a good air cooler like Noctua DH-15 but i think that not fit too ... In a future i will buy a Z370 ATX board to ocing the 7700k so i want a nice cooling ... What can i do for the little size in my case and board ? Thanks
well, you have a pretty big case with 170mm of CPU cooler clearance. so any air cooler will fit.
you can pick a noctua NH-U14. the temps will be just a couple of degrees warmer compared to NH-D15, but at much more compact size.
it will be same or better cooling as 99% of 240mm AiOs at lower noise.
Really ? But i have 3 kits of ram , and bad cable managment .. How do i see in my case what size that i have disponibility ? I have to see the size of the cpu to the ram , the cpu to the top , and the cpu to the lower ? So we can see what air cooling will fit
Buying 7700K now is bad idea when the 8700K is around...are you sure about that?
Z370 motherboards are not compatible with i7 7700K forget about it.
Thats im afraid off... That noctua D15s dont fit in my case... So if i go for a 280mm can fit it in front for sure i think, or another air cooling like Deepcool Lucifer that is smaller but i dont think it that cooling good a oced 7700k
again , you CANT USE i7 7700k on Z370 ATX motherboard. will NOT WORK.
you said Z370 lol
anyways , I would not buy Z270 and i7 7700k ... in your place . and the money you are spending on 280mm AIO cooler can be spent on Z370 motherboard now anyways ...
so why waste on expensive AIO cooler and ignore i7 8700K and Z370 ?
Get Z370 and i7 8700K now with Cheap cooler and sell your motherboard. later on upgrade the cooler when you have money.
NH-D15s is 160mm tall and compatible with your MB + 400c is 170mm CPU cooler clearance = will fit no problem
Okey, the Noctua thats is very good is the Dark rock pro 3 but dont fit, is bigger than Noctua D15s and the D15S is one of the bigger that can fit... I dont know if There is another Be quiet is smaller and good
