Air cooling for i5 8400 in Corsair 100r case
May 10, 2018
Hello fellow enthusiasts, I would like to know your opinion regarding air cooling an i5 8400 cpu in a Corsair 100r case which has only 150mm clearance. I'm looking at Cryorig's H7 cooler which has 147mm height as a possible cooling solution.
Now, would it be overkill to use that cooler because the i5 8400 is a locked cpu? Would the Cryorig m9i be a more sensible alternative or are there any other coolers out there worth checking out?
Thanks in advance.
May 10, 2018
So, you mean that the m9i is enough?
For case air flow, I have 2 120mm front intake and 1 120mm rear exhaust fans and will buy 2 more 120mm fans for top exhaust.
Forget the top case fans (you don't need them) & just buy the h7 .
Its a better solution than the m9I even with less case cooling.
You should never fit a top front exhaust with any tower style cooler anyway imo
Actually pulls air away from the cooler fan & makes it work harder.
Similar threads
