Air Cooling vs. AIO on a PC Running 24/7
I'm going to be building a PC soon that's gonna be doing some serious number crunching pretty much 24/7. It'll have an overclocked 6900k and some other components that don't really matter. My question is this: for this type of build where the cooler will be running basically 24/7 on a chip outputting a lot of heat, will an AIO like an H100 or H110 be reliable enough to not worry about a systemic failure that bricks my entire system? I've heard some horror stories about AIOs and feel like I don't have enough experience to make an educated decision, plus you never really see server hardware with liquid cooling and that worries me. I'm leaning more towards the Noctua NH-D15 right now.
While like I said, AIOs are super reliable today. Air coolers are always going to be more reliable than AIOs. Simply because of how they operate and are built.
I still vote air cooling.
Sound isn't a huge deal, I'm just worried about the liquid leaking while I'm not there and bricking everything.
Alright cool, I'll probably buy an air cooler then and get an h100 for my personal rig just to test it out for a while. Thanks.
Pumps do eventually fail, but usually last several years at least, and the processors are unharmed when they do - they just throttle until you notice. Leaks are rare but not non-existent.
You want a high-end Noctua or Cryorig air cooler. They're cheaper and perform similarly to high-end AiO coolers, with less noise.
Cryorig is a bit newer than noctua, and the cryorig looks ten times better. But both perform equally. And the noctua fans are slightly higher quality.
