Today i installed a CM hyper TX3 EVo to my FX6300 CPU(AM3+),and im unsure as to if my setup is optimal
Here is a pic of inside my case
http://postimg.org/image/xrwqp9lg7/
Fan on far right, pushes air in,fan on far left pulls air out.
The CM pushes air from south to north,this is installed as per the instructions.
As it stands i am getting lower CPU temps than the stock cooler,but my HDD are running a little hotter than before and i would also assume my Ram is aswell.
If i were to install the Cooler upside down that would then increase the heat of my GPU.
Not sure which way is best,can anyone offer any advice.
Edit: I also came across this pic http://www.coolermaster.com/uploadfile/fileproduct_list/P13021804159d85/PRDPIC/b6686bff3bef45d213e854605411ac43_1361408991.jpg
Installing it via this method does appear to be optimal,as it would push the air straight into my Extractor fan on the left,but it doesnt look like a very secure method of fitting,and may cause some rattling
