Air Flow In or Out
xeriian
68
Hey just got my self the Corsair Carbide Air 540 and the Corsair H100i mounted to the top of the 540. I have the front 2 fans sucking air in and the back fan blowing out the top 2 fans on the h100 are also sucking in. Can any one recommend an air flow for my case that will be good for temps and dust. Thanks
This is how you should have your case setup for the best airflow performance...
Where is the H100 mounted? Front and side panel fans should be blowing in. Top and back should be blowing out. For cooling you want more exhaust than intake. However this can cause some additional dust, but in my opinion it's not that much different.
