Hi all,
I have an HTPC inside an entertainment center that I'm trying to make quieter and cooler. The main limitation is the cabinet, there's not much ventilation room. The front is open and the back has three air vents at the top and a hole for wires but the computer case takes up most of the front opening so I'm sure it's not ideal. The odd thing is that the PSU fan is actually the loudest of the whole system. It's quiet when out of the cabinet so I believe the issue is that its heating up and cranking up the RPMs, making it loud.
There's not much room between the case and the back of the cabinet so the PSU is blowing right into the back wall. I've tried adding a case fan to the side of the PC case, and I just added another inside the cabinet but that hasn't seemed to help much. I'll link some pictures because its kinda hard to explain.
The obvious answer seems to be to cut holes in the back of the cabinet, but I'm looking for other solutions so please don't suggest that. Any other solutions are welcome!
pics of the situation:
https://imageshack.com/i/nrnv3aj
https://imageshack.com/i/nejq6cvj
https://imageshack.com/i/mruv5aj
https://imageshack.com/i/n6zax6gj
If I don't reply right away, give me a day or two, I'll be around
Build details:
Case- Silverstone ML04
PSU- Antec Green 380W (stock 80mm fan) intake is back of the psu inside the case, not bottom
GPU- Asus HD6450 fanless
CPU- core2duo, stock cooler
Case fan- fractal design ssr2-80mm
cabinet fan- 80mm coolerguys usb fan
MB- MS 7525, tuner card-avermedia duet a188, RAM- 4GB ocz, HDD- WD Green 2TB, optical drive- LG bluray whs140, Windows 8.1 64 bit
Build details:
