[SOLVED] Air flow SHARKOON VG4-W
Jan 8, 2019
38
Is the airflow in the SHARKOON
vg4-w good enough for rtx2070, i7-9700k ? It comes with 2 green led 120mm fans (1 high top in the background and 1 low on the front) and for the cpu i Will buy noctua nh-d15s. Will my temps be good? Full overclock (not gonna do that but is it possible)
I mean, it will "work". But I think that with a 9700k and 2070, you're going to have heat issues with two cheap 120mm fans. Especially since that case does not have much, if any, other ventilation. There are no signs of much, or any, grillwork anywhere on that case. It's mostly closed up, which means the fans are going to be the only real source of any air in or out. I think I'd make the change as fast as possible myself.
All you can do is try it. Monitor the temps. The CPU cooler doesn't make a lot of difference if you don't have enough case airflow for it to work properly.
I already have the 2070, but i think it's gonna be ok because i have a good cpu cooler ( i wanna upgrade the case anyway but i don't have enough money right now) do u Know any good cases not too pricy. Btw do u think the case Will be good for now? No overclock.
Ok, Ty for the help. Btw i have An i7-6700 and rtx 2070 all at Very good temps. Do u Know how long i should wait before i buy a new case and which one do u recommend for around 60€
Belgium, i'm gonna buy a 9700k but right now i already have the 6700, i just said that because Maybe if i can run 6700 stock cooler with good temps, i can run the 9700k with one of noctua best aircoolers at good temps
What cooler do you have now, with your 6700k?
This is probably the best case in that price range, for your region. There would probably be some much better options for about 20 more, but at that price, that case is much better than that Sharkoon. You'd probably need to buy a fan or two though, or swap the ones in your current case over to use WITH the ones that come in the Focus G.
I have the 6700 non k with stock cooler. I saw a yt video 2vs3vs5 fans and 2 fans is only 4 Degrees difference with 5 fans so i'm gonna stick with my SHARKOON vg4-w for now and upgrade in 2 months to a nzxt case. I'm not gonna overclock with my current case Tho. And my noctua cooler is really good so i think my cpu is gonna be fine. I already have a rtx2070 Running fine temps in this case so u think i can do 2 months with not damaging anything.
