Hello, I'm going to build a PC with Cryorig A40 as CPU cooler and the Design R5 as case.
(here the build with components details: http://pcpartpicker.com/p/6TZXjX )
The two Cryorig A40 fans on the radiator, if I'm right, are exhaust.
The Video card will be air cooled.
Do I need other fans as intake in the front in addition of the included one to have a positive pressure inside the case? Or a different air flow solution it would be better?
(I'm thinking to fix the radiator at the top of the case).
