Hi
After doing some clean up, managing my cables, buying a couple fans and a new heatsink, I started to experiment and see if I could improve my case airflow.
The case is a NZXT Tempest 410 Elite and currently looks like this:
http://i134.photobucket.com/albums/q100/shadowsins/IMG_4250_zpsec8e2894.jpg
My fan setup is as follows:
2 Front intake 120 NZXT performance fans (47 CFM / 1300 RPM)
1 Bottom Intake same as above
1 Top frontmost intake Corsair 140AF
1 Top rearmost exhaust Corsair 140AF
And the Hyper 212 EVO is pulling the air through the heatsink and pushing it out the rear of the case.
CPU is an I7 2700k Idle temperatures are between 28-34°C and wont go pass 55° at 100% (not overclocked)
GPU is an XFX 6970 and my only gripe is that it wont go below 40° on idle. Its currently running on the stock fan though I plan on upgrading to something like the Accelero Xtreme III in a couple of months.
Currently its summer time over here (Peru) so my room temperature is about 25°C for most of the day. give or take 3°.
As far as I know and given my history with PCs, I am getting pretty good temperatures (correct me if I'm wrong) for summer time and I only expect them to get slightly better when winter comes. Although winter here is incredibly humid (mostly over 90% humidity, no idea how that compares to other countries).
My most recent change was removing the rear exhaust and using it to blow air into the GPU which to my surprise made almost no difference on the GPU temps (2-3° at most).
I'm looking for advice and opinions on what to improve so that I can ultimately get some overclock done in the safest manner possible.
Thanks in advance.
EDIT: Currently my case is sitting on my desk raised 2" from the surface with 2 (wood lumbers?) , I'm looking into buying/making a fan filter for the bottom intake (some products are hard to come by here in Peru)
EDIT2: Wasnt entirely sure if this was the right forum
Thanks in advance.
