Airflow and fans configuration
Mtaz
16
Hello
I'm planning to upgrade my pc and add a nvidia gtx 960 and cooler master hyper 212 evo cpu cooler (my budget)
my case got 3 fans windows currently it have 2 fans installed front intake and back exhaust, side window has no fan on it
what would be the best way to get good air flow if i add an extra fan to the side window, intake or exhaust? Add to consideration negative and positive pressure (2 intake 1 exhaust and 1 intake 2 exhaust).
Thank you in advance
wouldn't it be better to provide some extra airflow to the system to help the heat sinks on the cpu and gpu to cool down ? since it's the only window i got to add more fans i was thinking about cooler master 80mm led silent fan, the ones on the front and back are cooler master 120mm sickleflow x
It messes up airflow completely, rather than cool air going in the front and being quickly evacuated out the exhaust, a mix of cool and warm air is just spread everywhere and then kind of getting exhausted. You're not cooking your GPU and CPU. You're cooling your motherboard, GPU, CPU, memory, PSU (sometimes), memory etc... Basically everything.
i decided to ditch this case and get one with better ventilation: 2 front intake - 2 top exhaust - 1 back exhaust fans
thanks for the heads up
should i cover up the unused at top and bottom near the psu or use a dust filter or just leave them ?
