Hi guys,
I'm building a new computer with my existing coolermaster haf 932 case, but with new contents:
4770k i7 intel quadcore processor
z87-a motherboard
gtx 780 graphic card
2x8gigs 2400 ram (with possible upgrade to 32gigs in the future)
650w 12g gold 80plus seasonic psu
1 samsung evo 250 gig ssd as main drive
( 2 other internal hdd for storage)
Noctua nh-d14 as cpu cooler (huge and has 2 fans)
as of now, my coolermaster haf 932 has not been modified and runs all the default fans that came with it.... with the top/back fans blowing the air out, and side and front fans sucking the air in.
with this new, more powerful build that i will be installing into the case, will the stock fans be enough? or should i add in more fans? or perhaps replace existing fans with more powerful ones? or even add 1 more fan to blow air from bottom (near the psu) up ?
thanks in advance
*and a side question:
the new z87-a motherboard only came with 2 sata 6 gb/s cables... but since my previous build was 7-8 years old... do i need to replace any of the cables? for example, the cables connecting my 2-3 hdd, power supply, were always a mess... all those regular old school 4 pins, 4 pins to sata,cables for connecting each hdd, graphic card, cd-rom drive were always all over the place and inter-connecting, and sometimes have to be bent in a weird way in order to have the sata end of the cable facing the rightg direction in order to connect more HDD.... are there any cleaner, more efficient cables i could use? are there any cables i need to upgrade to run the new system?
z87-a motherboard
thanks in advance
