-Intel i7 4790k CPU
-Coolermaster Hyper 212 EVO CPU Fan/Heatsink
-Gigabyte Windforce GTX 960 GPU
-MSI Z97 Gaming 5 Motherboard
-Corsair Vengeance Pro 2x8GB DDR3 2400mhz RAM
-EVGA 750w Supernova G2
-2TB Seagate HDD
-Phanteks Enthoo Luxe Black ATX Case
-4 case fans, Front Mounted 200mm, two top mounted 120mms, and a back mounted 140mm fan
I have very little knowledge on the airflow direction of components in my case. When I first built my PC I believed that I had set up the airflow properly to keep important parts cooled in the best way possible, but lately I have realized that my CPU's idle temps are about 40 C which seem high, and my GPU's top plate when running even low-graphics games becomes extremely hot to the touch even with both fans running and pulling air across the GPU. Attached is a rough sketch of the airflow of my case, and I'm even having difficulty telling if I am properly understanding the airflow. If anyone could please help me out and take a look at my system as well as the airflow in my case and tell me if I'm okay, if I can improve it, or if it would possibly help to use a PSU cover that came with the case to separate the heat of the PSU from the rest of the system (I don't even understand how the air flows into and out of the PSU and whether or not its dumping hot air into the case). The airflow/fan I am most confused about is the one boxed in red in the picture.
As far as I understand the current airflow is as follows: The 200mm front fan pulls air into the case and blows it across the HDD cages, and the PSU pulls air from under the case and pushes it out the back and (maybe towards the GPU?!). GPU fans are under the card pulling air from the direction of the PSU (bottom), across/through the GPU heatsink and plate, and towards the CPU fan/heatsink, straight through the CPU fan and up through the CPU heatsink. The air is then pulled out the top of the case towards the two 120mm fans and out the back towards the 140mm fan.
Stupid question but very difficult to find the answer: Do small fans and case fans ALWAYS blow air in the direction of the support braces? Like towards the plastic parts that holds the motor housing in the center? Thanks!
Thanks in advance for any suggestions, corrections, or tips! (I am not against upgrading to an all-in-one loop for water cooling)
[/URL][/img]
-2TB Seagate HDD
